575D Self Leveling Linkage - NEED HELP
ETD66SS
04-07-2005 18:09:03
Ok, fixing some things on my new toy.
FORD 1993 575D TLB.
I noticed when I first bought it, there was a clevis with a busted off piece of threaded rod in it connected to nothing, I wondered what it was.
When I got my manuals, I discovered it was the Hydro Mechanical Self Leveling Linkage.
Keeps the bucket parallel with the ground while raising a load. I figured that would be a cool feature, and I'd like to get it working again.
I checked out the prices of the parts I needed, and decided they were too much, so I made my own.
After bending a section of threaded rod the first time I hooked it up and tried it out, I then realized someone had put the bell crank on upside-down. Once I figured this out, I thought I was all set...
I tried to follow the instructions on how to setup this linkage from the operators manual I have, but it seems like the loader & bucket movement always go farther than the bell rank and lever will allow on the spool valve, and I end hp bending the hell out of the nice new linkage I made up.
Anyone have experience with this linkage?
Question for operators, do you use this feature a lot? Or do most guys remove the linkage and just operate the bucket tilt & loader height combination manually when lifting a load of material?
I feel like I wasted 2 days on this little project...
ETD66SS
04-07-2005 18:32:33
 Re: 575D Self Leveling Linkage - NEED HELP in reply to ETD66SS, 04-07-2005 18:09:03
If someone could help me out by measuring the long tube on thier machine?
I need the dimension from the center of the 5/8" hole on the clevis end, to the end of the tube...
If you have a parts manual, the part I need measured is E7NNL882AC - Tube. Found on page 18B01.
Thanks...
