t340 engine
BOB BOOTH
02-26-2005 21:10:30
my t340 gas engine was freeze cracked badly when i bought the crawler, can i use an engine from any other tractors;or does it have to be from a crawler? thanks anybody
rpg52
03-02-2005 09:40:21
 Re: t340 engine in reply to BOB BOOTH, 02-26-2005 21:10:30
For the serial # range that bobdozer mentioned, the block casting number is 367727R2. I think it is found just below the top of the block where it joins the head.
Ray
bobdozer
03-01-2005 14:45:53
On the 135 crawler engine serial number 11391 to 100500 the head has nine bolts after that they switched to a 14 bolt cylinder head they also went to a one piece rear main and a few other changes.
rpg52
02-28-2005 09:15:31
Hi, I replaced my T340 engine about a year ago - same problem, left plain water in it. The casting number on the block is the key to finding the correct engine. The c-135 was used in the 340 and a couple swathers and combines of the '60's era. I bought a rebuilt block and had the valves ground on the old head. That seemed to be the cheapest alternative, rather than buying an old block and rebuilding it. I'll try to find the specs on the casting number and other info. Ray
J.C. IN AZ.
02-27-2005 20:07:13
The T-340 and the 340 Tractor share the same Engine,Gas or Diesel.A replacement Engine should be no problem.
bobdozer
02-27-2005 06:21:05
Be carefull not all 135 engines will fit as the back of the block has a different bolt pattern to the bell housing
charlie
02-27-2005 03:54:56
The same engine was definitely used in some of the ag tractors from the same era. I think the engine model is C-135. You can probably track it easily on the redpower (IHC) web site. Many other parts were interchangeable too.
hector gemme
02-27-2005 01:39:24
HI I think you can use some motor from farm tractor.I have td5 parts but no more motor.hector
