Jdemaris, more 350b steering
MrBill
01-09-2005 19:43:02
JDEMARIS wrote an excellant writeup at the attached message thread. Thanks, I have added it to my service manual.
Now to my problem: my 350b left side slips while pushing.
Does that mean the clutch adjustment is too tight and does not totally engage? After a few hours working, I had a full load in the bucket and when backing out, would not back straight out but kept turning because the left track was not pulling. Per JDEMARIS instructions,I tried to follow them. On the left, the ball joint link is adjusted all the way out, no more adjustment. On the right, the 3/4 brake bolt will not turn. The head acts like it is recessed in the lever and will not turn the 180, either direction.
Another problem, the foot brake does not work. The linkage under the floorboards acts like it is not connected to anything at the rear. Where is it supposed to connect? I can udjust the yoke on the linkage all the way either direction and no change. The pedal goes to the floor with no effect.
Thanks for any help, MrBill
JimInOz
01-10-2005 01:39:48
 Re: Jdemaris, more 350b steering in reply to MrBill, 01-09-2005 19:43:02
Hi Mr Bill,
Make sure you get the Pressure plate checked out.Broken springs,warped/flogged out sections ,etc.
I took mine to clutch guy..he said to get new one,as most parts that move had enough wear to interfere with good driving performance.Steering wasn't my problem...driving ability was.Good luck.
