Pin for blade brace on a Cat D7-17A
andy R
01-05-2005 19:16:46
I have a Cat D7-17A with a cable blade. Looks to be sort of an original blade for the machine. Towards the front of the blade push arms on each side there are braces. The brace runs from the push arm towards the center of the blade. I believe they are adjustable. Sort of fit into the blade and the push arms with a "socket". One of the pins that holds the arm into a piece of the socket at the blade arm must have just DROPPED out. The pin isn't all that long - Maybe 4 inches. I haven't measured the hole but looks to be about the diameter of at least a golf ball or bigger. Any ideas???? How is the pin held in there. Was it mushroomed at the top and bottom. I believe there might have been some "spline" like things at the very top. Does anyone know the size or what could I put in there??? I assume a piece of mild steel shaft would work. Thanks
hector gemme
02-11-2005 04:37:40
 Re: Pin for blade brace on a Cat D7-17A in reply to andy R, 01-05-2005 19:16:46
HI I HAVE SOME D7USE PARTS BUT NOT THE ONE YOU NEED
Billy NY
01-07-2005 04:28:37
You should have either a "7A" or a "7S" model blade, hard to tell from your description.
The "A" type is a manually angled type blade, the blade is balanced on a trunion in the center of the "C-Frame" and has removable pins along the push arms on either side, pull the pins and angle to either side, best suited for grading and pushing off fill.
The "S" type is a straight blade, both the "A" & "S" allows the pitch of the blade to be adjusted. This means you can adjust the cutting edge angle to be agressive or relaxed in a manner of speaking. In basic terms it's the angle of which it engages the ground, the brace tilts the top of the blade forward increasing the bite of the blade or lets you tilt it back if you want less of a bite, all depending on the soil conditions you are working in.
Cat did print manual for just the blade, I have one for the "A" blade for my D7, which I was fortunate to find on e-bay, used to see these often, click on the link below, or you can try Midland Press, for a licensed reproduction which is good print quality, copy paste the following into the browser:
Link
ksb
01-06-2005 19:06:26
andyR
Sounds like you have lost a pin out of a diagonal (arm) brace. If you look on the back, and the upper right side of the dozer you should find a small metal plate with the dozers s/n on it. If the plate is gone, which in some cases it is, you should find two small pin holes where it was, you can wipe the paint off with some paint remover and you should find the s/n stamped in the metal between the small pin holes.
Post the s/n, and someone can give you the parts number you will need to get one from Cat. Or you can do as NC Wayne has suggested and make your own.
NC Wayne
01-06-2005 15:46:31
Get you a piece of 4140 or equivilent steel stock for your pin. That's what we alwasy make replacement pins out. It's both hard enough to have a decent wear resistance and tough enough to not simply bend where a plain mild steel pin would. As for keeping the pin in, if you could have somebody turn you one with a head on it and then go in the other end and through drill it and use a big cotter pin or a bolt for a keeper. If you don't want to invest in having one turned you should be able to take a straight piece and either weld a big thick washer on one end for a head or simply drill both ends for a keeper. Either way make the pin long enough to put a large washer between the keeper pin and the pin boss to keep the boss from getting eat up by the keeper. Hope this helps.
andy R
01-06-2005 21:29:26
 Re: Pin for blade brace on a Cat D7-17A in reply to NC Wayne, 01-06-2005 15:46:31
Thanks guys. Thats what it is .. a pin on the diagonal brace. Do you guys know what diameter that would be?????
