JD 500 Backhoe swing problems
Skip
08-25-2004 04:58:18
My problem is that the boom will not stay in one position so I am thinking about rebuilding the swing motor or is it a valve problem?. Has anyone done this with sucess? What would it cost? Someone sugested I put a cylinder on it insted.
Skip in CT
Jonathan in MA
08-25-2004 16:28:15
 Re: JD 500 Backhoe swing problems in reply to Skip, 08-25-2004 04:58:18
I"m assuming its the barrel style swing "cylinder"...It won"t hurt to diasassemble and see what condition its in, in there...but usually at this point in time , its usually not pretty....If it swings when it shouldn"t in both directions I"d lean towards the problem being in the swing cylinder..
Skip
08-26-2004 05:08:41
 Re: JD 500 Backhoe swing problems in reply to Jonathan in MA, 08-25-2004 16:28:15
Jonathan have you ever been into one? Is this a vane motor that might have stuck vanes? Any help is apprieciated.
Skip
Jonathan in MA
08-26-2004 18:03:08
 Re: JD 500 Backhoe swing problems in reply to Skip, 08-26-2004 05:08:41
Single Vane attached to the center spindle...sometimes the vane loosens...creates gouges in the inner diameter of the barrel....but you could be lucky....wont know til its disassembled...
