1961 Case 310 Crawler will not turn
Paul
07-28-2004 22:50:52
Crawler will go forward and back by pulling the sticks when the trans. is in gear but will not turn.
the tractor vet
07-31-2004 19:48:27
 Re: 1961 Case 310 Crawler will not turn in reply to Paul, 07-28-2004 22:50:52
Some one put the wrong grease in the transmission and rear end , they are only suppose to use MINERAL OIL grade 90 , i know from experance on this one as we did that once on the one i had . Tryed to clean and flush and install the wright stuff and it still would not turn , ended up putting in new brake bands and while the back was off we washed out the rear end with parst cleaner the stuff that ya can't get anymore and after we where done it would darn near turn on a dime.
Karen
08-01-2004 18:21:27
 Re: 1961 Case 310 Crawler will not turn in reply to the tractor vet, 07-31-2004 19:48:27
I believe he said his brakes ARE working. The tractor will only drive while the brakes are on. It sounds like a planetary problem. As far as mineral oil, I have been able to get it at Walmart and Advantage Auto Stores. It is GL1 gear oil.
Don L.
08-01-2004 09:36:39
Where can this oil be found to buy some?
Don L.
george md
08-01-2004 11:48:15
 Re: 1961 Case 310 Crawler will not turn in reply to Don L., 08-01-2004 09:36:39
Don, Same gear oil that road ranger transmissions call for 90# GL-1 .
george
Karen
07-29-2004 04:28:50
I don't know what you mean by pull the levers to make it go forward and backward, but if it will not move unless you pull a brake lever and hold the brake, it sounds like you have planetary problems. If so, I know a source for parts and/or advice. Email me and I can send you the link.
