Moving a dead dozer six inches
Andy
07-24-2001 16:31:50
I need to move my HD7 just a few inches to clear the rear sprocket enough to access a drive pinion panel. Does anyone know a trick for doing this. Obviously I don't have anything except my 180 AC that can pull it and I'm pretty sure it will just spin the tires.Many thanks.I've seen this done with pry bars and come alongs but can't remember how.
etshobby
07-25-2001 21:57:46
 Re: Moving a dead dozer six inches in reply to Andy, 07-24-2001 16:31:50
when moving large or heavy equipment or even a couple barns, plus garages I have had sucess by jacking up and placing two planks down with 3/4 to two inch pipe nipples between the planks and you can push some things even by hand if smooth cement floor one plank will work with pipe between plank and floor.
hector gemme
02-10-2005 08:01:09
 Re: Re: Moving a dead dozer six inches in reply to etshobby, 07-25-2001 21:57:46
HI I HAVE SOME HD7 USE PARTS
Max
07-25-2001 18:41:06
Not all that familiar with the HD7 but what I used to do with the Case crawlers was to cut an 18" diameter log to fit under the rear hitch, start up the unit and use the hydraulics to lower the blade or bucket to raise the machine up. Once up, I could then used a come-a-long, a bottle jack, another tractor, skid steer loader, or one time even used a garden tractor. Good luck and remember pins go outside in to remove and inside out to install, its easier for the next person to swing the hammer from the outside to remove the pins. Good luck.
ferrell freeman
07-25-2001 13:12:05
You would need to have some kind of dead head to use a come-a-long .Then find somewhere to hook to in the front or remove several track shoes from each side behind the front idler hook a chain and come-a-long on both sides to our dead head .The pry bars can be used by inserting pry bar though the sprocket and track chain and pulling.
FRED
07-24-2001 17:32:22
Put a hyd. jack under a growser. You may have to do it more than once, but it will move. FRED
BOB W.
07-25-2001 16:31:30
 Re: Re: Moving a dead dozer six inches in reply to FRED, 07-24-2001 17:32:22
I would try the tractor to pull it crawlers move easier than you would think . i have seen D10 cats move by themselfs on a slight grade.
Andy
07-24-2001 17:48:00
Thanks Fred. Still working on this HD7. Is a growser one of the sprocket shafts?
oldtime
07-25-2001 06:38:10
 Re: Re: Re: Moving a dead dozer six inches in reply to Andy, 07-24-2001 17:48:00
Growser is the plate that bolts onto the track chain the plate which contacts the ground i hope this helps we all have to start somewhere best of luck
Paul
07-25-2001 18:16:05
 Re: Re: Re: Re: Moving a dead dozer six inches in reply to oldtime, 07-25-2001 06:38:10
I agree with a previous post that dozers move easier than you think. I have moved D7's and D8's with just a plain old 4WD pick up.... If the blade is still attached and on the ground dig a small trench under the blade for your cable/chain to go under blade and when you drive forward the blade will come up. If you still cant move it, remove the floor plates and disconnect the driveshaft from the clutch housing.Put trans in low gear. You can now put a bar in between the transmission yoke and the u-joint and turn the input shaft of the trans. It wont take to long and you will have moved your 6 inches.... Email me if you are uncertain of what I am describing and I will try to do a better job of explaining this. Good luck, Paul
Lilian
07-26-2001 12:29:50
 Re: Re: Re: Re: Re: Moving a dead dozer six inches in reply to Paul, 07-25-2001 18:16:05
I agree also, We moved our TD20B wit a old 65HP 2wd tractor. We only blocked the 3P hydraulic lifter under the front of the crawler in order to put weight on the rear wheels.
I hope it will be possible for you,
Lilian
ryan olson
07-27-2001 11:33:27
 Re: Re: Re: Re: Re: Re: Moving a dead dozer six inches in reply to Lilian, 07-26-2001 12:29:50
hi i really agree me and my grandpa once moved a good sized crane for about a mile once with a ca allis and a farmall m we took out a drive gear in the crane put the farmall in front with 3 logging chains and the ca in back pushing with a 4 in. round oil pipe and it went pretty good we even just pulled it with the m once to move it into the tree line. Or you could try to pile as much weight on the back of your allis and deflate the tires in back alittle and i'd almost bet that she moved!!!
