1940s td-6 with hydrolic bullgrader blade
kevin in wa.
07-13-2004 07:02:39
where can i find serial# and manf. date there is no plate on the control board? how much does it weight
king of obsolete
07-14-2004 05:37:47
 Re: 1940s td-6 with hydrolic bullgrader blade in reply to kevin in wa. , 07-13-2004 07:02:39
if you go to redpower forum we can post pictures, there are 2 kinds of blades from those years, thanks
kevin in wa
08-02-2004 01:58:46
 Re: Re: 1940s td-6 with hydrolic bullgrader blade in reply to king of obsolete, 07-14-2004 05:37:47
Does anyone know how much a td-6 weighs with a bullgrader blade? Is it possible to remove the flywheel without removing the engine. It looks like I might be able to get it out by just removing the clutch,linkage, the steering or the brake peddles because,the ring gear needs to be flipped. Any info would be helpful! I don't even know what year it is. All I know is someone said, "it looked like something from the 40's".
