coolant temp
dd
07-08-2004 20:23:12
I have a d20 komatsu, what is the normal coolant temp in summer, my gauge is running 220 is this too hot for a diesel engine?
Greg D
07-10-2004 17:17:22
 Re: coolant temp in reply to dd, 07-08-2004 20:23:12
First off what is your ambient temperature? Acceptable range is about 100 degrees over ambient, here in my area that can and is sometimes a normal operating temp. I would also install another gauge, preferrably a mechanical with a bulb on the end, to determine how accurate your other gauge is. As was also mentioned, check the rest of your system to be sure air flow is clear, radiator tubes clean, belts tight for fan and water pump if it is belt driven. Don`t overlook the air filter for a cause of overheating, lack of air will cause overfuel situation and can overheat. Good luck!!!!! !!!!
RAB
07-08-2004 23:22:29
Is this guage that accurate?
Regards, RAB
Roy
07-08-2004 20:53:25
Sounds kinda warm.. Is your temp gauge accurate ?Plugged radiator,defective thermostat , loose fan belt,bottom hose sucked shut, compression in coolant from liner holes,worn out ? Could be anything...
