Case 1816 Tecumseh OH160
Arnold
07-03-2004 09:31:43
I recently purchased this skidsteer and have noticed oil comming out of the engine breather compression is 150 + psi with a few cranks hot & full throttle...oil filler seal O-Ring looks OK and there is no oil appearing around the push rod tubes....??? There is alot of oil weeping from around the valve cover...it's tight and facing the right way with the breather.....any thoughts on this from u folks before I rip her apart?????
thanks ajs
