440 icd ring gear and carrier removal
higgins
06-17-2004 15:59:37
still cant get that s.o.b. out of housing with that pto shaft running along side it, maybe right after hell freezes over it"ll roll right out there
Lavoy
06-17-2004 17:59:42
 Re: 440 icd ring gear and carrier removal in reply to higgins, 06-17-2004 15:59:37
The ICD's have the big transmission, I don't bleieve there is room to remove the ring gear due to its larger diameter. You will need to at least drop the bottom shaft down in it's bearings a little bit to get the carrier out, if not remove it all together.
Lavoy
higgins
06-17-2004 18:33:01
 Re: Re: 440 icd ring gear and carrier removal in reply to Lavoy, 06-17-2004 17:59:42
thanks for info lavoy.that will be my next step. regards; higgins
