Parts for Clinders Case 31 backhoe 31 loader
Ben Butzen
05-08-2004 20:44:08
Yes I have a Case 530CK (gas)tractor with a 31 backhoe 31 loader. My problem is leaking clinders. My swing clinders both have external leaks as does my Crowd and Boom clinders. Can anyone help me with what to do?. Can I still buy replacement parts for these clinders or not. If not could the clinders be made to fit todays parts?. Ive went to a couple Case Dealers and they told me (don't know where you're going to get parts for them.
Doc Holiday
05-09-2004 10:14:41
 Re: Parts for Clinders Case 31 backhoe 31 loader in reply to Ben Butzen, 05-08-2004 20:44:08
Where in the world are you located?!?
Don't worry about getting parts for those cylinders, if the dealer doesn't want to take the time to open up his parts book, find the correct numbers and hand you the parts off his shelf I suggest you find another dealer.
Head off to your local independent hydraulic shop, they can either kit the cylinder for you or if you want to do it yourself pull it apart before you go and take the parts in to the shop so there is no doubt you get the correct parts.
Kits should run about $20.00-$30.00 a cylinder.
Have Fun!
