350B Steering
Jim
04-22-2004 14:10:58
I just rebuilt both sides of the finals on my 350B crawler I did all of the adjustments just like the service manual said.Aftermarket clutch plates were purchased and brake bands,The throwout bearings came from JD. One side has a new pressure plate from JD and the other side has a aftermarket plate.The dozer turns fine on the side with the JD plate, But you have to pull real hard on the other side to get it to turn I have been over the adjustment on both sides My question is could it be a bad pressure plate? or am I missing something I am not looking forward to pulling the final off again
fasteddy
04-22-2004 19:34:42
 Re: 350B Steering in reply to Jim, 04-22-2004 14:10:58
Jim, go down the list of post here about 27 where mr Bill ask about clutches. It might help,Jd maris is real sharp on these crawlers.
fasteddy
04-22-2004 19:15:52
Jim, couple of things to try,You should be able to adjust levers so when you pull them back real slow the clutches should disengage and machine should coast to a stop. This will tell you that they will disengage.Next is you will have to see if each brake is working. If they check out then I suggest starting over and check all of the adj.. I hope you set it with a gauge!!! good luck .
