2-53 Detroit Diesel 440icd
scott
03-30-2004 12:01:04
So where can I get some high compression pistons for this engine??? is that ok to do????
Can the current liners be bored?
I got the pistons out, the liners are still in and didn't budge, these are a press fit into the block, right??
thanks
scott
BJ
04-01-2004 08:26:21
 Re: 2-53 Detroit Diesel 440icd in reply to scott, 03-30-2004 12:01:04
The liners are dry liners and will probably require a liner puller. Be careful of piston pack choice. I would go back with the piston listed on the engine type plate. Be sure to measure liner protrusion as the liners worked up and down in the 2 cycle.
buickanddeere
04-05-2004 09:19:41
 Re: Re: 2-53 Detroit Diesel 440icd in reply to BJ, 04-01-2004 08:26:21
53 series liners are wet. N series sleeve piston kits are dirt cheap. Install N35 injectors at the same time and upgrade the blower seals.
scott
04-02-2004 06:59:34
So where is the engine engine type plate????
thanks
scott
jdemaris
04-01-2004 19:29:05
My 3-53 has wet sleeves. Is the 2-53 different?
jdemaris
03-30-2004 19:46:43
No, they push in by hand. Tend to come out a little harder when they get rusted.
