420C Lavoy?
Bernie in Ma
03-09-2004 08:51:10
Last fall my steering clutch was slipping. While I pulled the final drive I found the discs were all OK, it was because the fingers on the pressure plate were sticking way out and hitting the throw-out bearing. I put in a used pp that I got years ago in case I needed it from a guy who said he knew how to adjust the fingers. Apparently he didn't, because now it won't throw out the clutch. The manual doesn't say a word about adjusting. Do you have any pointers? TIA
Jim in michigan
03-10-2004 11:27:45
 Re: 420C Lavoy? in reply to Bernie in Ma, 03-09-2004 08:51:10
hey bernie.. I may have to do the same to my 420, hopefully it just has ice in it though,,havent had it out since the day I had trouble with it,,when it gets warmer I will try it again,,muddy out now and tracks would tear up my driveway...Jim
Bernie in MA
03-10-2004 16:21:14
 Re: Re: 420C Lavoy? in reply to Jim in michigan, 03-10-2004 11:27:45
Hi Jim. I was going to use mine to pile brush the way it is, but I decided to tear it apart now while it's in the shop and not full of mud. I'm going to go with a new pp; pulling it apart twice is enough.
Jim in michigan
03-10-2004 20:59:06
 Re: Re: Re: 420C Lavoy? in reply to Bernie in MA, 03-10-2004 16:21:14
I am going to tear mine down in the spring and rebuild the engine,,probably put a new drive clutch in then if it looks very worn,I am not sure,, but I may not have to remove the engine to put rings and rod bearings in it,, looks like the plate under the engine may come off and make enough room for the pan to come off,,,Jim
Bernie in MA
03-11-2004 08:13:05
 Re: Re: Re: Re: 420C Lavoy? in reply to Jim in michigan, 03-10-2004 20:59:06
They tried to sell me a main clutch instead of steering yesterday. Good thing I had them open the box so I could see it, knew it was too big. FYI the price on it is $237.50. Steering is about $20 less. If it wasn't so hard to tear it apart I'd try cheaper alternatives that might not work.
Lavoy
03-14-2004 20:16:13
 Re: Re: Re: Re: Re: 420C Lavoy? in reply to Bernie in MA, 03-11-2004 08:13:05
I have steering clutch parts for about a third of what Deere is.
Lavoy
Lavoy
03-09-2004 12:31:19
Yes, there is a tool for setting the fingers. I have them for $10 if you want one. I am leaving today for Gathering of the Green in a few minutes, but will try and check on messages while gone.
If you want one, and need it fast, send me an e-mail through my website, and I will see if I can mail one from Moline.
Lavoy
