350B electric problems
SteveB
02-06-2004 05:09:46
Well I went and replaced the key and pushbutton switch on my 350B, She still wont't kick or do anything for that matter. I checked the harness connector and removed the three heavy wires and cleaned them well. When I jump 2 of the three heavy wires at the harness the machine will crank.But will not start I'm sure due to the fact that the injector isn't getting power to open? What should I look for now? Should I cut the harness apart at the connector and splice??
bob
02-06-2004 19:38:06
 Re: 350B electric problems in reply to SteveB, 02-06-2004 05:09:46
I'm starting to wonder if you've got gasoline, bad fuel or something bad in your fuel. That would cause a shaft to shear in the injector pump, meaning you're getting no fuel to injectors. Maybe crack fittings & see if pressure forces fuel out.
Lavoy
02-06-2004 07:43:10
We just went through exactly what you are describing. Replaced the dash side wiring harness, no more problems. Lavoy
Hurley J. D.
02-06-2004 06:13:19
Install a jumper across the terminals of the ammeter and see if that will let the machine start. I had a bad ammeter at one time on the 450B and could not crank the machine.
