Service Manual 580 K
Ben Hodges
01-30-2004 17:04:50
Lookinf for a service manual for a 580K Loader back hoe. Can anyone tell me how much it cost to have the Hydralic controls seales. I have a few leaks there. Ben
AJ
01-31-2004 03:11:24
 Re: Service Manual 580 K in reply to Ben Hodges, 01-30-2004 17:04:50
If your leaks are coming from around the spool valves it is a simple job,each valve has an o'ring near the top to change the top o'rings first you need to pressure clean the top of the valve block,then take the clevis pin out of the offending valve,on the bottom of the block take off the cap of the said valve,lower the spool down enough so you can pick out the o'ring at the top,fit the new ring and smear some clean grease on it,gently push the spool up and put the bottom cap on,connect the lever and job done,don't take the spool valve out of the block.keep everything clean including your hands,leave all the equipment on the ground and wobble the levers about to relieve any pressure in the system,take the cap from the hydraulic tank to let the air escape.Good Luck AJ
Ben Hodges
01-31-2004 07:02:49
 Re: Re: Service Manual 580 K in reply to AJ, 01-31-2004 03:11:24
Thanks for the responses. They sure will help and appreciated Ben
JCmarleau
01-30-2004 19:09:42
Yes I have one if interested my e mail is [email protected]
