Crawlers and Loaders
Alvin n Ms.
01-26-2004 07:13:09
Check this site out. Deanco D8L Dozer, s/n 53Y03325: St. Blade, 2 KG Blades, Ripper, Winch 2000 Cat D5M-XL Dozer, s/n 6GN01834: OROPS, Sweeps, 6-way Blade, 24" SBG Pads, Finger-tip Control, 2056 hrs John Deere 450G-LT Dozer, s/n 870277 John Deere 400G Dozer, s/n 52457 Komatsu D41P Dozer, s/n 20289 Mitsubishi BD2G Dozer, s/n 388 John Deere 790D-LC Excavator, s/n 1007919 John Deere 644A, s/n 23961 Cat 426 Loader Backhoe, s/n 7BC1626: Cab Cat 416B 4WD Loader Backhoe, s/n 8ZK9768 Ford New Holland 555E Loader Backhoe, s/n 10081 John Deere 310A, s/n 286197 John Deere 7210 Tractor John Deere 1070 Tractor, s/n 15775 Ford 5610 Tractor, s/n 76771 John Deere 1250 Tractor, s/n 4367: Front Loader John Deere 4850 Tractor, s/n 8841 Kubota L3010 Tractor, s/n 120986 International 1440, s/n 7697 Ford F350 Crew Cab Truck, s/n 70709 KMC 8-Row Vertical-fold Strip Till: w/Row Markers, w/JD 8-Row Stack-fold 7300 Vacuum Planters, 36" Rows KMC Vertical-fold Ripper Disc: Shaper 8 Row w/Row Markers, Tiller Vator Doors, 36" Rows Crowley Hydra Flex 6-Row Peanut Inverter Case 580 Loader Backhoe, s/n JJG0257151: 1064 hrs John Deere 9960 Cotton Picker, s/n 4646 John Deere 272 Excavator, s/n FF0272X220267 1993 Komatsu PC200 Excavator, s/n A70823 Komatsu D38E Dozer, s/n 85679 Cat D5B Dozer, s/n 25X1108 Dresser TD12 Dozer, s/n 1400719 JCB 214 Loader Backhoe Bomag BW142 Roller, s/n 510112688 John Deere 25 Excavator, s/n D001070 2001 Dodge 3500 Truck, s/n J226860 Massey Ferguson 135 Tractor, s/n 1808137 John Deere 4700 Hi-Boy Sprayer, s/n X002539 Lilliston 9004 BushHog, s/n 1100203 Cat D5H Series II Dozer, s/n 3MD00506 John Deere 215 Disc, s/n 011743 Cat 12F Motor Grader, s/n 89G1897 CRAWLER DOZERS Cat D6H Dozer, s/n 4RC01507: OROPS, 6S Blade w/Tilt Cat D6D LGP Dozer: EROPS, 6S Blade w/Tilt Cat D6D Dozer, s/n 75W02937 2001 Cat D5M LGP Dozer, s/n 3CR01708: OROPS, 6-way Blade, FTC, 3000 hrs 2000 Cat D5M LGP Dozer, s/n 3CR01360: EROPS, A/C, 6-way Blade, New U/C 1998 Cat D5C Hystat III Dozer, s/n 6CS0288: OROPS, 6-way Blade Cat D5C LGP Dozer, s/n 62L00499: OROPS, 6-way Blade, 24" Pads 1994 Cat D4H III Dozer, s/n 8PB06117: EROPS, 6-way Blade Cat D4H LGP Dozer, s/n 9DB00650: OROPS, 6-way Blade 1999 John Deere 450H Dozer, s/n 874319: 6-way Blade, Root Rake, 561 hrs 1999 Case 550G Long Track Dozer, s/n 0256597: OROPS, 6-way Blade Case 450 Dozer, s/n 3045161: 6-way Blade 1999 Komatsu D39P Dozer, s/n 96296: OROPS, 6-way Blade, 26" SBG Pads Komatsu D65E-6 Dozer, s/n 25066: OROPS, St. Blade w/Tilt Komatsu D31P Dozer, s/n 45181: OROPS, 6-way Blade, 24" Pads Komatsu D21A-6 Dozer, s/n 60899 Mitsubishi BD2F Dozer, s/n 1B000511 CRAWLER LOADERS 1998 Cat 953C Crawler Loader, s/n 2ZN1577: EROPS, A/C, 4-in-1 Bkt. 1998 Cat 953C Crawler Loader, s/n 2ZN01513: EROPS, A/C, GP Bkt. w/Teeth, Very Good U/C Cat 933 Crawler Loader, s/n 8FL359: OROPS, GP Bkt. Cat 931 Crawler Loader, s/n 8N0443 HYDRAULIC EXCAVATORS 1998 Cat 345BL Excavator,
jim/pa
01-26-2004 14:56:34
 Re: Crawlers and Loaders in reply to Alvin n Ms., 01-26-2004 07:13:09
whats the url, can you post a link? jim
Alvin n Ms.
01-27-2004 06:37:46
 Re: Re: Crawlers and Loaders in reply to jim/pa, 01-26-2004 14:56:34
Just type Deanco in the search block, click on search,then select deancoauctions. You can click on the blue highlites for pictures of the equipment. alvinnms
jim/pa
01-27-2004 09:23:07
 Re: Re: Re: Crawlers and Loaders in reply to Alvin n Ms., 01-27-2004 06:37:46
thanks al, label me dense.
