1955 JD 420 crawler value
Ed Hadaller
01-01-2004 14:53:20
Found out about this 420 crawler and went to take a look. It has been sitting for a couple years. All complete, very good tin. Has a winch, canopy, a big 6ft blade off of it. All the gauges are good; says 715.9 hours (not faded) The tracks are not worn much. I had no way of seeing if the motor was free. There is a 40 crawler for parts that has to go with it. What would the price range on this crawler be. Thanks for any info, Eddie Hadaller
jack hayden
02-08-2004 20:22:08
 Re: 1955 JD 420 crawler value in reply to Ed Hadaller, 01-01-2004 14:53:20
Hi Ed, If you decide your not interested in this machine, pease let me know. I'm in western mass and would be interested. Thanks. Jack Hayden
Bernie in MA
01-03-2004 19:09:27
I bought one with a stuck engine last year for $2500. I got it unstuck, head checked out and valves reseated and replaced all ignition, carb rebuilt, etc. I've got another $1000 into it, $300 of which was to replace the cracked hydraulic pump. I got a good machine for no more than what running ones are selling for here, and I know what's been done to it. It has a twin cylinder blade, winch, and logging boom.
Pete/ME
01-03-2004 03:17:21
Put a battery in it, if it starts, run it around the yard, see if the blade has sufficient down-pressure to lift the front of the tractor, and if the winch works, I'd pay $3,500-$4,000. If the hour clock is accurate it sounds like a find.
i r baboon
01-01-2004 18:50:33
where r u? if u dont get her, let me know? be blessed. is gas eng?
Mike
01-01-2004 15:33:37
I wouldn't put much more than $1500 in it.You are starting with a stuck motor,and most likely stuck steering clutches,or possibly bad clutches and brakes. At least at $1500 you could get your money back out of it for parts if its too bad to fix.
