7.8 ford vs cummins 8.3
carl
12-23-2003 18:08:27
I have a chance to buy one of a pair of identical tandem dumps;one has a 7.8 ford,the other a 8.3 cummins;all other specs are alike. which one should I pick?
scotc
01-01-2004 20:20:20
 Re: 7.8 ford vs cummins 8.3 in reply to carl, 12-23-2003 18:08:27
the M11 (8.3) cummins has got to be one of the biggest turds of a truck engine ever built. hope its got lots of gears behind it, you will need it in hills, flat land aint bad. To get any real horse from a cummins means moving up to the N14 and it gets awful heavy if you ever have to back in anyplace soft. I think if you look really close you may also find the ford motor is an IH DT466 in disguise, kinda like the powerstrokes.
george md
01-02-2004 19:40:24
 Re: Re: 7.8 ford vs cummins 8.3 in reply to scotc, 01-01-2004 20:20:20
Scotc, M11 and 8.3 are not even related ! L 10 and M 11 are similar as in 10 liter and 11 liter. 8.3 is a C series consolidated diesel and is big brother to the B series that is in the dodge pickups. L 10 and M 11 work well in single axle trucks but none of the above is big enough for a tandem truck running in hilly country . NT series cummins has the HP and torque to handle a tandem and last , last one I had in for repair had 633,000 miles of dump truck service before needing overhaul,was not dead then just worn out. george
Andrew
12-27-2003 14:39:32
Well id go with the 7.8L i know a guy that had one and never had a wrench on it depends on how you treat them... good service and you will get a good engine but from what the other guys say go with the cummins personaly i dont like cummins there like Cat (yellow hand grenade) and cummins are in the same point to (black hand grenade).... but if you really want power put a 6V71T in it if you tune it up right you can get 300 H.P and have lots of power to and good on fuel. i know a guy that did that to a F800 and has very good luck with it he has put on over 600 000 Km and never had a to do any thing but clean injectors and change oil and filter... and he bags that truck...
gatractorman
12-26-2003 02:53:49
Go with the Cummins, my F-700 service truck has the 6.6 Ford diesel a size smaller but built similar to the 7.8 no wet sleeves and very expensive parts, the 8.3 Cummins is a real diesel with replaceable wet liners.
JBL
12-24-2003 09:46:10
I would go with the 8.3L cummins, mainly because of the name they have. The 8.3L in a tandem dump application should be setup for atleast 350hp and with aftermarket parts you can get 425hp out of them. I don't know much about the ford engines but I am guessing it is the same scenario.
george md
12-23-2003 21:03:07
Carl, Unless you have all down hill running , neither one is big enough for a tandem dump. On flat land a 300 cummins will do , if you have any hills get 350 cummins or larger . In this area the guys run 400's and 444's. The last on I overhauled out of frame was a 444, we put it in to replace a 300 . Owner said it sure did level out the hills. george
