188D Head Removal
DOUG
10-28-2003 07:40:16
I have a 450 Case Crawler with a head gasket or cracked head, Can some one please give me the procedure for removing it and the torque spec's. And valve lash spec's. Or email me an excert from a shop manual, Would be verry helpful. Thanks DOUG
Steve Schmittgens
10-29-2003 14:20:23
 Re: 188D Head Removal in reply to DOUG, 10-28-2003 07:40:16
Valve Clearance hot & cold for intake & exhaust is .014 inch. cyl head studs with flange nuts torque to 90-100ft.lbs., cyl head bolts with 12 pt. heads are 105-115 ft. lbs, & cyl head stud nuts are 95-105 ft. lbs. If you need anything else feel free to call me @ the shop @ (314) 966-6692. Steve
