Case 310 dozer
b hart
05-07-2001 17:55:06
Any one know how many links of track chain a case 310 dozer should have? The more i look at mine the worse looking it gets. Don't know if someone took out a few links to tighten it up or what.Mine has 30 links in it!!!!! !
Half Track
05-08-2001 05:06:33
 Re: case 310 dozer in reply to b hart, 05-07-2001 17:55:06
b hart: The odds of having 3 links removed is slim to none. I say you have one link removed max.
Now the easy way to tell how many links you should have. For std. machines, four roller machine has 31 links & five roller is 33. This might not cover special order machines or some that have been changed. HT
brian hart
05-08-2001 18:50:47
 Re: Re: case 310 dozer in reply to Half Track, 05-08-2001 05:06:33
Thanks a lot half track.Now as for getting new track rails $550 per side $200 for track bolts and nuts 80 dollars freight.Mine has three rollers on it could you tell me what model of 310 this is by searl number only says case 310 on tag.It has side slop in rear sprocket about one half inch.The track pads have four bolt pattern!!!!
marlowe
05-07-2001 21:56:09
310 series c d e f g have 33 links at link pitch of 5.875
