jd 450b dozer gear raking noise, looking for input
arnold b
10-09-2003 18:28:31
when trying to shift the transmission from gear to gear [1,2,3,4] the gears rake and i have to shut off the engine before i can get it back in any gear. do i just need to adjust something or is there other problems. if anybody knows how to adjust it i would appreciate any information they have to offer, thanks, ..... just another [new] crawler enthusiast
gatractorman
10-10-2003 03:19:48
 Re: jd 450b dozer gear raking noise, looking for i in reply to arnold b, 10-09-2003 18:28:31
Thats common on these older tractors it takes a little time for things to stop rotating after you push in the clutch, or if it still wont shift you may be in need of main clutch adjustment or the main clutch is stuck to the flywheel, does it stop pulling when you push the clutch in?
