420C
Bernie in MA
09-27-2003 17:34:27
I pulled the track off my 420 today to get started rebuilding the steering clutch. The axle has loose bearings on the sprocket end. No grease has leaked out. Can the bearing be tightened by taking shims out at the inside end? TIA
Lavoy
09-27-2003 21:32:30
 Re: 420C in reply to Bernie in MA, 09-27-2003 17:34:27
Bernie, You add shims to remove freeplay. If you do this, while you are in there, make sure the axle retainer bolts are tight. Lavoy
Bernie
09-28-2003 05:29:28
 Re: Re: 420C in reply to Lavoy, 09-27-2003 21:32:30
Thanks about the retainer bolts Lavoy. I thought after I posted I might have it backwards. Bernie
