1973 John Deere 310 loader/backhoe brakes
Paul
09-20-2003 18:07:13
hello, Would anyone know do I have to split the tractor apart to get at the brakes. The brakes are very hard to press down, it almost feels like the are in a locked position? I don't know if the is a parking brake lock on the these brakes as this tractor is new to me? Any info would be greatly appreciated. Thanks, Paul
Jonathan
09-22-2003 14:17:20
 Re: 1973 John Deere 310 loader/backhoe brakes in reply to Paul, 09-20-2003 18:07:13
But before you rip into that...might want to check the pedals at the shaft they pivot on...almost sounds like they are binding there with rust. A little time with some penetrant like PB Blaster or equivalent and some manipulation and you might be back in business. Wouldn't be the first time pedals froze like that !!
Robert
09-20-2003 20:09:00
it has been a fue years ,lower sabilzers and backhoe,flor jack under tran,remove wheels,remove deck plats and seat,remove back hoe uper suport uper pins(one on each side).Remove bolts for axle to back hoe fram. raze up on flor jack ,use small battle jack to raze uper support bar,remove axle to tran bolts ,use host to waler axle out.be shur to replace big smap ring on plantary while you are there. hope this will help Robert
Paul
09-21-2003 07:12:43
 Re: Re: 1973 John Deere 310 loader/backhoe brakes in reply to Robert, 09-20-2003 20:09:00
Robert, Thank you so much for the information. So are you saying that I do have to take the backhoe off also or just disconnect the rear from the hoe. Thanks, Paul
Robert
09-21-2003 12:18:35
 Re: Re: Re: 1973 John Deere 310 loader/backhoe bra in reply to Paul, 09-21-2003 07:12:43
just the rear pins for uper support bar.this bar gose over the rear axles and can be jack up to get anof room to work there.you could remove the back hoe from the tractor but that adds lots of work to the job.good luck, Robert
