430 dozer
Gary
09-01-2003 03:13:30
Hi guys I have a chance to buy a 430 dozer. The under charage is in good shape. New sprockets, chain and pads look real good. Had new steering clutches put in it. It has been out side for 4 or 5 years with a can over the exaust pipe and no water in the oil and the oil looked new. Blade and all is in good shape. The hood has some dents in it. I think i could get it running easy, but don't know what to offer for it. What do you guys think. Also i think it has a reverser and 5 speed. Thanks Gary
Gary
09-03-2003 02:25:12
 Re: 430 dozer in reply to Gary, 09-01-2003 03:13:30
I made the guy an offer for it and will know this week if it's mine. I have a 350 that has been all redone and will let go if i get the 430. Is the reverser in the 430 a manual clutch system? Thats what it felt like. I guess all the parts for a 430 are still available from some where. Thanks for all your input. Gary
Lavoy
09-03-2003 20:33:37
 Re: Re: 430 dozer in reply to Gary, 09-03-2003 02:25:12
Gary, They are a clutch type reverser, not to be confused with a full hydraulic reverser like in a 350. You must push the clutch in each time you shift the reverser, or you will greatly accelerate wear and damage on the clutch discs. Lavoy
Joseph Giordano
09-02-2003 18:54:15
If you end up not getting this machine I would be interested in it. Please contact me at [email protected] Someone mentioned the reversers are weak, also keep in mind that more than likely even if the clutches are new you will have to free them up from setting so long.
jdemaris
09-01-2003 16:10:14
In central New York State it would go for around $4500. Check the reverser carefully, they're weak.
