Am I on the right track?
D. Andrews
06-19-2003 10:48:37
Ha, no pun intended... D-20p-5 Komatsu, I noticed a lot of slack in the blade the last time I ran it, further investigation showed that the pins were not worn but the housings were. I concidered replacing all of it, but cost is a big issue. I started looking for options, and came up with what is called garlock bushings. they are a hardened steel backed with a teflon/brass inner, self lubricating that I can get real reasonable for all 6 bushings ( the blade has 3 piece fork type set up with round pin in center ). I may have to turn the pins down .037" and slightly bore the mounts out to make a tight fit. Do you guys think this is a good idea or?..... D..... ..Oh, these are the main hinge pins for the blade up and down.
scotc
06-21-2003 17:29:18
 Re: Am I on the right track? in reply to D. Andrews, 06-19-2003 10:48:37
way i look at it, if it works for a couple more years, it'll pay for itself. Maybe have the bushings machined and drill the housings for greease fittings
