Allis Chalmers HD6 Throwout Bering Assembly
Mike Davies
04-09-2001 19:17:13
Bad news for me. I need one of these Throw-out Bering parts for my Allis HD6 Crawler. I need:
1. Sleve Assembly 078116
2. Yoke Assembly 078134
3. Clutch Shaft 085774
4. Berting Caps (Blocks X 2) 053929
Does anyone know where I might find these good used parts?
Thanks in advance for your help
hector gemme
02-09-2005 05:13:45
 Re: Allis Chalmers HD6 Throwout Bering Assembly in reply to Mike Davies, 04-09-2001 19:17:13
HI I HAVE HD6 PARTS
drott
04-10-2001 09:47:52
I should have one here for that machine or close by.
Email me at [email protected] or visit ibdozing.com, have a lot of AC crawler tractors there.
HD6 is a good machine.
If I cannot come up with the shafts that are good. A machine shop can make them for around $60 dollars. Use Miraloy or some very hard rod that just barely machineable. They are not a hardened steel and and you only need the key way cut and the notch for the interlocks put on.
As for the bearings. Torringon bearings will work for the blocks and for the bearings on the clutch housing. On my next rebuild project, I will use rulon bearings, Teflon Impregnated and less likey to cut into the yolks sleeve and on the the clutch housing shaft levers.
Mike Davies
04-09-2001 19:18:44
Sorry, I left the wrong e-mail message in the first one.....it is [email protected].
