Need info on 210c tlb fast
allen
05-09-2003 18:08:27
found a jd 210c diesel tlb 2 stick with 12,24 and 36" buckets, new battery 4000 hours asking 14000 is this a good deal? is this a good or bad machine? owner says were made from 88 to 92.thanks
mikeinmo
05-09-2003 20:32:02
 Re: need info on 210c tlb fast in reply to allen, 05-09-2003 18:08:27
Don't know much about price, been away from JD hoes for sometime. Use to run a 210C full time it was an ok machine. A little light for some things. Never had any transmission/shuttle trouble. JD did 2 recalls on our machine if memory serves me correctly, one was on the brakes the other on the latches that secured the rear window above your head. Didn't really see any improvement in the brakes after the recall work. Deere said they had trouble with the rear window falling on your head if you swung it up out of the way for digging with the hoe. Original latches were flimsy plastic, new ones were heavy duty steel with some tough springs to keep them in place. Loader arms are straight pieces all the way from the pivot point on the tractor to where it attaches to the bucket. They will get in the way some if you do a lot of truck loading. Messed up a few sideboards till I got use to them. Rear stabilizers could have been a little longer for more stability when trying to dig over the side. Plenty good though for digging straight behind you. All around good machine, just the smallest of the C series hoes. Lightweight for moving, stays on top better in the mud, downside is if you are doing a lot of heavy digging it will fall a little short. Sorry for the long post. Just my two cents worth on what I can remember. Good Luck and God Bless.
