Td 6 steering clutch
BOB
04-20-2003 10:17:39
can anyone offer any good advice on pulling steering clutches out of td6.i have one that will not disengage and one that will not engage.thanks, bob
dozin hal
04-20-2003 14:00:47
 Re: td 6 steering clutch in reply to BOB, 04-20-2003 10:17:39
Bob I just finished pulling two on two different tractors. Grind down the box end of a 10" to 12" wrench. Make them pretty thin and narrow. Take another boxend wrench and cut out about 100 degrees out of the end so you can turn the bolts after you break them loose. Every time you take out two bolts, roll the tracor to make two more bolts come up on top. Each time take two or three bolts out of the drum as you go. You will have to jack the tractor up to get the forks out. Loosen from underneath, but be careful. Mark the drum and the final drive hub. One bolthole is off center not 4.25", a little longer. When you get the two halfmoon pieces out, push the shaft back towards the drum. Both of mine came out without compressing the clutch drum. If you are lucky you can roll the tractor with a bar stuck in the drum holes. My parts tractor was frozen up on the other side and barely moved while pulling with a farm tractor. If in a shop on concrete, jackup the affected roller frame and it should turn with a bar.
hector gemme
02-09-2005 10:49:12
 Re: Re: td 6 steering clutch in reply to dozin hal, 04-20-2003 14:00:47
HI I HAVE SOME TD6 PARTS
