TD 340 no down lift on dozer blade
Archie
01-24-2003 07:47:29
I have aTD340 crawler and it does not have down lift on blade.Is this right? When you let the blade down and it hits the ground it stops. THANKS Archie
dale rocholl
04-12-2003 10:06:01
 Re: TD 340 no down lift on dozer blade in reply to Archie, 01-24-2003 07:47:29
do you have float on your dozer. we have a td340 and if you push the lever all the way ahead it is in the float position. this mean that it will float on the top of the ground, works best for back draging. try easing the lever forward. it might be the filter or screen is plugged.
Archie
01-24-2003 16:55:53
 Re: Re: TD 340 no down lift on dozer blade in reply to CRAWLER HEAVEN, 01-24-2003 10:39:19
I will try as soon as it warms up alittle.It was 5 here this morning.The blade should pick the front of dozer up I think.Is that right?THANKS Archie
