420C
Bernie
11-04-2002 17:16:38
I bought a 420C this fall that the motor had been stuck for about 8 years. I got it freed up and running this past week and found the right steering clutch is stuck. I haven't tried bumping a rock or tree yet. If that doesn't work is there a way to loosen it without pulling the final drive?TIA
JD
11-05-2002 05:39:18
 Re: 420C in reply to Bernie, 11-04-2002 17:16:38
Bernie, You'd better get used to it. Learn the machine inside and out and it won't take all that long to disassemble either end, even out in the middle of the woods. If the machine is abused or neglected, you will be fixing it. Do yourself a favor and decide to do it right. We get a lot of work from our 420 but it took a lot of work to bring it back to working condition after others neglect.....
JD
11-05-2002 05:31:54
Lavoy
11-04-2002 17:47:06
Bernie,
Hate to break it to you, but if it doesn't let loose after you bump something, you will have to pull the final, especially if it has sat outside at all. I have worked on more than I can count, and have never yet been able to get one to loosen up without pulling the final.
Lavoy
