I.H.500c steering clutchs removal
BOB SCHULTZ
08-28-2002 20:36:44
I am having trouble removing inner bevel gear shaft. any tips 1968 500c THANK BOB
Rick from Paso
09-02-2002 22:44:06
 Re: I.H.500c steering clutchs removal in reply to BOB SCHULTZ, 08-28-2002 20:36:44
Bob, I have a manual, I can scan the relevant pages and e-mail them if you want. It says to use a slide hammer to pull the pinon shaft. Also pull the shaft out only far enough to remove the clutch and use penetrating oil to aid shaft removal. Also becareful not to drop the inner thrust bearing assemblies into the sprocket drive housing. Using a slide hammer as the shaft moves out, it must be carefully tilted down to prevent the aforementioned thrust bearing from dropping. Support the clutch assembly being removed so that it does not drop. Good luck, e-mail me if you want jpgs.
t4mike
08-29-2002 20:22:37
Why do you want to remove it if your working on clutches? If only wanting to remove clutch packs, remove other side pinion, and then push bevel gear shaft through enough to remove pack, then push back to center or pass center to remove other pack.
ben
08-29-2002 09:03:37
bob if by chance it is like the shaft on the 500 it should be threaded in the center size is i belive 7/16 screw a long pice of all thread into it and pull the shaft out.
