I.H.500c DOZER ENGINE 155ci 3 CYLINDER 1968
BOB SCHULTZ
08-26-2002 16:46:04
NEED ANY INFO ON 155ci ENGINE IF THE SAME AS 179ci OR WHERE TO LOCATE 155ci THANKS BOB 732 9224542
victor lavin
06-14-2006 01:34:12
 Re: I.H.500c DOZER ENGINE 155ci 3 CYLINDER 1968 in reply to BOB SCHULTZ, 08-26-2002 16:46:04
if you need a info abaut the IH 500c,i have the onwers manual and the service manual , if you liked, just send to me a messaje
Rick from Paso
08-26-2002 23:12:48
Bob, What is the question? The D-155 engine was used in the 500C and 500E dozers and are in the same family as the D-179 engines which were used in the 2400A/B(tractor), 2405B(loader), 2410B(loader), 2412B(hoe), 3400A(loader), 4500A/B(Lift). Same number of cylinders, larger displacement due to longer stroke (128.59mm vs 111.13mm) but same bore (98.43mm). I don't know if they are bolt-in compatible ( I doubt it ). I have a manual if you need info.
