Cat D6 HELP!!!
Michael (WV)
07-01-2002 21:01:15
Hi, evevy one
Just found a Cat D6N dozer with hyd,blade and winch on back of dozer.Where is the serial # located? The dozer has 6 cyl,motor with a pony motor on the end of the diesel engine,about what year were they made? Does anyone know how to adjust the steering it has a hyd setup? anyone know what it would weigh? I sure could use some manuals on this dozer! THANKS for all the good advice. Michael(WV)
hector gemme
02-09-2005 07:22:38
 Re: Cat D6 HELP!!! in reply to Michael (WV), 07-01-2002 21:01:15
HI I HAVE SOME D6CAT PARTS
ScottL
07-03-2002 10:41:42
ACMOC has been moved...new site address:
info
07-02-2002 22:05:01
old cat site ACMOC.org
terry thornton
09-07-2002 17:04:46
 Re: Re: Cat D6 HELP!!! in reply to info, 07-02-2002 22:05:01
pony motor running but foward lever to engage cat engine won't engage it anymore. can anyone tell me what went wrong?
terry mitchell
10-30-2002 11:05:47
 Re: Re: Re: Cat D6 HELP!!! in reply to terry thornton, 09-07-2002 17:04:46
sounds like the ponymoter shaft is broke
Bob /Ont.
07-02-2002 13:26:13
Michael Look on the upper left of the rear of the steering clutch and bevel gear case. I think you are talking about an 8U or 9U serial# machine. the engine serial# should be the same if the engine is original. I'll tell you more when we know for sure.
Later Bob
