Massey Ferguson Backhoe
Allen Tate
06-24-2002 20:50:48
I have a MF-40 backhoe. The bottom pin on the dipper arm broke. I can have this pin made my question is that the old pin had a hole in it in the middle of the pin through the pin from side to side of the pin. Does anyone know if this hole has a purpose and if so is it important. Any help with this will be appreciated. Thanks Allen T.
vincent
08-11-2002 18:34:43
 Re: Massey Ferguson Backhoe in reply to Allen Tate, 06-24-2002 20:50:48
Can anyone tell me where I can find a cab for an 1981 60H massey Ferguson Backhoe
gerry
06-26-2002 22:03:22
just a guess but probably had a grease nipple on it somewhere at one time an was used for lube
gatractorman
06-25-2002 02:18:03
sounds like a place for grease to get out to grease bushing, the old pin didn't have a grease fitting in it did it?
Allen Tate
06-25-2002 09:17:58
 Re: Re: Massey Ferguson Backhoe in reply to gatractorman, 06-25-2002 02:18:03
No grease fitting was in it when it came out and where the hole is it is not sealed you can see the pin except out at the ends where it goes through the dipper on both sides . it also goes through 2 ears on the tractor right below the circular cylinder but is open in the middle.
gatractorman
06-25-2002 13:55:10
 Re: Re: Re: Massey Ferguson Backhoe in reply to Allen Tate, 06-25-2002 09:17:58
Dont know then, would be hard to say without seeing it, may be someone changed the pin before you got it and just used what they could find, if there is nothing in the hole and no obvious use for it I would say it wasn't needed.
Allen Tate
06-25-2002 19:45:10
 Re: Re: Re: Re: Massey Ferguson Backhoe in reply to gatractorman, 06-25-2002 13:55:10
Thanks for your advice gatractorman. I am haveing one made minus the hole I could see no need for it to be there. Thanks Allen
