Compression reading on T6 C248 engine?
Jeff
06-17-2002 21:45:36
Does anybody know what kind of compression reading I should get form the c248 engine on my T6 if it were new or rebuilt? Is there a minimun acceptable reading that would indicate that it's time to rebuild or do the four cylinders just need to be reasonably clse?
Thanks, Jeff
pete .alberta.
06-19-2002 16:02:08
 Re: Compression reading on T6 C248 engine? in reply to Jeff, 06-17-2002 21:45:36
new or rebuilt should be in vicinity of 135-150 p.s.i..All cylinders should be within 15-20 lbs of one another.Older engines should give 90-100 psi.Engines down to 60-70 can be tested by giving a couple of squirts of oil in bore,and testing again.If readings come up 15-30psi ,then rings are getting weak.
Jeff
06-19-2002 16:44:05
 Re: Re: Compression reading on T6 C248 engine? in reply to pete .alberta., 06-19-2002 16:02:08
Pete, Thanks, for the reply. I was a little concerned because I initially checked the compression while hand cranking. I know that's probably not good but the starter was out at the time. I have since replaced the starter and got better readings. Three cylinders read 135 and one at 140 now. The engine seems to run strong but before I got one at 100, two at 60 and one at 10. This seems like it would indicate a slow leak??
Thanks, Jeff
