Which dozer to get.
Andrew (OH)
05-31-2002 09:56:42
I am looking to buy a dozer to rebuild and then dig a pond with. Do any of you have any preferences as to which one to get. I don't have any experiance dozers so I need some help. Like which ones would be the easiest ones to rebuild and which ones will do the most work. If any of you know where I can get one, please let me know. I am in Central Ohio.
Kern K McClure
03-13-2003 12:49:16
 Re: which dozer to get. in reply to Andrew (OH), 05-31-2002 09:56:42
I Have a 420 John Deere Crawler 1957 I just refinished. Selling because I Want A loader or Radios for my Air plane. I Dug a Small pond this 2 cyclinder Crawler has a great amount of power easy to get around with however it is only a straight push blade no angles.Will make you a good operator Ha Ha. Needs some Adjustment in tracks for they were put on new this winter.E-mail me I'LL send pics Price $8,000 Firm I put $5,000 in parts have reciepts Factory parts no junk .I'am in upstate N.Y also has new Paint (New rebuilt radiator, New Starter,Battery,Exhaust Manifoild,Complete Electrical, Gas bowl and line),and holds 60-80 lbs oil pressure The parts listed in ( ) are not part of the $5,000 rebuild they were extra approx $1,000 to $1,500 have Reciepts. Someone will get a good machine for this price.
Celeriac
06-01-2002 18:47:12
Andrew, The other guys are right that you may be better off to rent or if you do buy get the best machine you can afford. Buying cheap and fixing is usually more expensive, not to mention the investment of time. For everything you can see that is wrong there's bound to be some hidden problems as well. Grainger tractor is near Medina, I've stopped there and they are quite accomodating. Check out rockanddirt.com, machinerytrader.com etc. to get a feel for prices and availability. Good luck.
the tractor vet
06-01-2002 18:14:16
Not tryen to be smart but for what you are going to spend on buying a used dozer and fixen on it and all the work that is involved why don't ya just rent a dozer for a mounth and when you are done ya send it back and you have had your fun and you got off cheep.
clark
06-01-2002 15:45:09
Andrew, If you want to get a dozer to dig a pond i would sudjest getting a dozer that is in good working order unless you want something to fix and cost you a tone of money.. you can get a decent 450 JD in good working order with decent undercarriage for around 8 to 10 k.. if you get a old worne out dozer 450 JD then you can expect to put 3 to 4 k in the engine and another 3500 into the undercarriage and who knows what else you may need, stearing clutches?? brakes?? radiator>?? best to get one already fixed..
wrenchman
05-31-2002 22:29:48
try Granger Tractor,#1-800-878-5533.ask for D4Dan...is in ohio too...good people...
