Will 19 wide tires fit on 480C case bhoe? have 17 now
ben
05-28-2002 10:31:46
hey i have a 480C backhoe with 15 wide rims and it now has 24x17" tires. itlooks like i would have room on the tractor for 19 inch wides, wondering if anyone else has tried this. i am a little worried about the tire coming off of the rim and stuff. also is there a reasonable way to change them yourself or is just a huge headache. its costs around 50 bucks each to change them. thnx for any advice ben
Tom H
05-28-2002 11:44:19
 Re: will 19 wide tires fit on 480C case bhoe? have 17 now in reply to ben, 05-28-2002 10:31:46
Ben;
I have a 580E backhoe. Original tires were 17" wide. Put 19" wide and althought I thought there was room found after you fill tire with appropriate air and get the weight of machine on them the side walls rub the side of the cab. Remedy is I let some air out. Still can't run chains on rears if I wanted to. Would like to in the winter when plowing my drive but such is life.
Hope this help!
Tom
ben
05-28-2002 11:46:20
 Re: Re: will 19 wide tires fit on 480C case bhoe? have 17 now in reply to Tom H, 05-28-2002 11:44:19
oooh ok thnx i was afraid of something like that!! thnx a lot
