Cat D4 with Trackson Loader
Mike
12-31-2000 08:37:16
We have acquired a '47-'48 model D4, needs a lot of work. In particular the hydraulic pump is out, Model #44, 7W1616. The valves are still good, pump is gone and relief valve needs replacing. Does anyone know of a good source for these kind of parts or any other parts as well? Also the nameplate say's gpm is 37, does anyone know at what pressure. Considering changing out pump to something else but the volume won't be that high, so will also need to change out cylinders or movement will be too slow.
Also need lower tank for radiator, cracked because it froze. Any and all suggestions will be appreciated.
OzDozer
01-13-2001 06:07:44
 Re: Cat D4 with Trackson Loader in reply to Mike, 12-31-2000 08:37:16
Put your post on Link
