Cletrac moled AGH
Frank K
07-18-2000 08:46:19
If any one could help me get an approximate date on my Cletrac AGH, I would sincerely appreciate it. I was looking for an electric starter instead of crank starting, but there appears to be only one place possible, but according to the manual it is for a gear drive generator. We still use our Cletrac, affectionally named "Gravel Gertie". It was slightly modified 50 years ago and had a hydraulic pump added and driven off the fron crank shaft by a #50 chain. The blade is cut from a grader blade with 5" square tube as arms to the under carriage trunnions. I need a set of leaf springs or an educated guess of how many and what thickness they need to be. The original broke years ago, and my grandfather put solid square stock steel in its place! Extremely rough, plus it cannot be good for the machine getting jolted like it does. Any assistanc would be appreciated. Thanks Frank
