V has no fire
DCM
06-28-2006 20:26:38
Have a 1941 Case V with the small continental that I have not run in 2 yrs. Tried today and no fire to plugs,where to start? what to look for? a little green around this kind of quandry.Thanks for any suggestions.Dan in AB
mech
06-30-2006 12:58:30
 Re: V has no fire in reply to DCM, 06-28-2006 20:26:38
i would start at the battery with a test light...follow the voltage down to the points...ex..switch,coil,side of distributor,then the points themselves.if you have voltage up to there..plug your test light into a plug wire..dose it light the light when you turn the engine over
C. Amick
06-30-2006 09:23:51
Coils seem to like to go dead when they sit around. First start with the suggestions below.
Martini
06-29-2006 06:02:34
With mine the on/off switch is a little dicy.
The points might need cleaning and the wiring
should be traced for wear and breakage.
I also find the high voltage coil connection can get oxidized with the aluminum type cap contacts. A VOM can be your best friend to trace problems.
Be careful...I recently bought a 'cheap' VOM
and it was dead out of the box.
Dale(MO)
06-29-2006 05:05:20
I would start with putting in a new condenser. Check the points while you are there. Condensers will go bad just setting.
Dale(MO)
