Roosa Master parts
Doug Overkill
06-28-2006 19:20:25
I am still fighting away with this Roosa master model DBGFCC431-27AJ pump. I have discovered that the transfer pump blades which are the one piece style are 0.025" shorter than minimum allowed. Perhaps this is why I have no flow. Does anyone know who I can order a set from? If not does anyone know what the overall length new is and I can make a set. The manual only lists a minimum length of 1.093" long.
Thanks.
jdemaris
06-30-2006 05:54:35
 Re: Roosa Master parts in reply to Doug Overkill, 06-28-2006 19:20:25
The new blades are cheap. You can replace with the original one-piece - or put the steel sring-loaded in - but if you do the latter you need a lot extra parts to go along with the change. I stopped buying my parts from Roosamaster/Stanadyne and now buy Spaco. It's an Italian injection parts company that has a full line of replacement parts for Roosamaster, CAV, and many others. Try: www.usdiesel.com US Diesel in Fort Worth Texas is a dealer and will ship.
800-328-0037. They have an on-line Roosamaster parts catalog. A few sample prices and part numbers:
JDB pump seal kit - Stanadyne # 24371 - Spaco U24371 $12.10 JDB pilot tube - Stanadyne # 16320 - Spaco U16320 $4.83 JDB pump vanes - kit 20803 - Spaco 09528
