more 530 hand clutch questions
INCase
06-28-2006 05:44:03
I've been looking at a 1964 530 gas Narrow front with draftomatic 3pt triple range (see post from around june 22nd). Took it out for another spin. The handclutch does not stop the tractor in either position. Figuring worst case, what would it cost roughly to replace the hand cluch disks?
With a bad hand clutch is 1750 reasonable? its in good shape (orginal paint) but could use some back tires and seat springs. Also, Where is the hydraulic dip-stick? Thanks.
JRT
06-28-2006 22:06:20
 Re: more 530 hand clutch questions in reply to INCase, 06-28-2006 05:44:03
Speaking of hand clutches, here is a story about one on a 430 I bought a while back. When I looked at the tractor I saw the hand clutch would not release. It seemed locked in place. The owner did not even know what the lever was supposed to do. I Thought maybe it was too tight or something. I bought the tractor anyway but did not give a lot for it. When I got it in my shop , the first thing I wanted to see was what was wrong with the handclutch. Opened it up and guess what- Someone had done a real nice job welding it shut. It was ruined. It makes me wonder why. Was it loose and he did not know how to tighten it. Was it ratteling making too much noise and he wanted to quiet it down? I guess I will never Know the answer But I would sure like to know why.
630crazy
06-28-2006 08:27:17
I have heard the clutch disks are the same as the disks from an early 60's Chrysler 3 speed auto. Check NAPA before you order them from your local Case dealer. The triple range dipstick is for the hydraulics. The 28' tires are very common and the seat springs will run about 80 or 90 bucks. I would think $1750. is a pretty fair price.
jake rose
06-28-2006 06:09:21
Just did the hand clutch on my case 300 ran about 159.00 bucks
