vao runs again !
JKW
06-26-2006 15:23:03
The VAO came back to life with the rebuilt carb and distributor. When I turn it off I can hear liquid running inside the engine for about 5 seconds is this normal? Thanks for your help. John in B.C.
'53 VAI Guy
06-26-2006 20:00:30
 Re: vao runs again ! in reply to JKW, 06-26-2006 15:23:03
JKW, that's the sound I like to hear. It means the oil was getting every where it should have been when it was running. You will hear that when you add oil to the crankcase as well (splasing down from top to bottom). Have fun.
Sam#3
06-26-2006 18:16:26
You're probably hearing the oil draining down from the upper cylinder and oil filter. Maybe the coolant thermosyphoning until it cools a bit.
JKW
06-26-2006 22:00:06
 Re: vao runs again ! in reply to Sam#3, 06-26-2006 18:16:26
Thanks! I was concerned because I had Cherokee 4.0 that made that sound and the mechanic said the check valve by the oil filter was at fault. It seems strange that the oil filter is upside down on the VAO I usually fill the filter before I install it, Maybe this tractor is meant for Australia export lol ;)
