Case 530 CK TLB
Tim in Mohnton
06-26-2006 06:04:07
Hi everyone, I'm wondering if you can help with this one? I have a Case 530 CK with a backhoe on it. Everything seems to have good power, but the backhoe will only do one thing at a time. I can't make it go up and over or crowd and curl etc. Does anyone know what might be the problem? It's pretty hard to do a nice job only being able to move one cylinder at a time.
Thanks in advance for your help,
Tim
Phil (NJ,Az,Sask)
06-26-2006 22:02:10
 Re: Case 530 CK TLB in reply to Tim in Mohnton PA, 06-26-2006 06:04:07
Tim, Sound like you have a volume problem. The Filter is upside-down near the FEL controls with a Green (for good) gauge. Make sure you have enough Fluid. The level is checked by removing
the 1/4" plug near the Rad (left side) of the Loader Frame. Fill the main FEL loader frame (left side ~3/4 up) until fluid runs out the 1/4" plug. (fluid is in both Loader sides)
Hope this Helps,
