fuel cap for a 18-32 case cross motor
jess jenkins
06-25-2006 19:29:08
i am trying to locate a fuel cap for a 1926 18-32 case cross motor.also,i need a kingston carburator float. thanks
Fred Milner
06-27-2006 18:55:27
 Re: fuel cap for a 18-32 case cross motor in reply to jess jenkins, 06-25-2006 19:29:08
You can get a new float for you Kingston carb. from Otto Gas Engine Works Elkton, Md. 410-398-7340 You need the 3 1/4" Kingston Float For 18-32 case. It was $17.00 last fall when I got mine. It has 2 small bolts but you only use one and it will work just fine. My case runs good using it. If you need anything else on that email me at [email protected]. Good luck.
jess jenkins
06-28-2006 08:22:55
 Re: fuel cap for a 18-32 case cross motor in reply to Fred Milner, 06-27-2006 18:55:27
thank you.
Bobcat
06-27-2006 06:09:00
I have a extra crossmotor fuel cap but the threads are not very good, It will screw on with a little patience. If interested let me know! As for a float for a kingson the original was cork. Not good. I have a L-3 on my 12-20 and found a L-3 from a Case "L" is a direct fit and it is made of brass. You could probably get a new one of those if it is the same size. Measure your fuel bowls diameter post back if you want to know if your's is the same size!
jess jenkins
06-28-2006 08:19:39
 Re: fuel cap for a 18-32 case cross motor in reply to Bobcat, 06-27-2006 06:09:00
let me get with the farmer i'm helping locate these parts, and i'll get back with you as soon as possible thank you jwj
Jess Jenkins
06-30-2006 15:45:45
 Re: fuel cap for a 18-32 case cross motor in reply to jess jenkins, 06-28-2006 08:19:39
I sent you an e-mail, did you receive it? The farmer I know is interested in the cap. Thank you.
Brian in Ohio
06-26-2006 07:07:16
I'm not 100% sure about this, but I think they used the same fuel cap on all of the Crossmotor tractors. (Maybe not the 40-72) So, if you find one from a 12-20, it should fit.
jess jenkins
06-28-2006 08:28:51
 Re: fuel cap for a 18-32 case cross motor in reply to Brian in Ohio, 06-26-2006 07:07:16
thank you
