Case IH 3230 Excessive Smoke Problem.
4010 Pride
06-25-2006 09:42:04
Have a Case IH 3230 that smokes excessively at low or high RPM"s, load or no load on the engine. Hours are unknown, tractor seems to run really good. Sounds good, has descent power. Seems to lag alot when wide open in road gear. Probably bcs it"s 4wd with a small 52hp 4cyl 206ci engine. The smoke is a black like color with a somewhat blue tint to it. Is this maybe a fuel pump issue or does it need to be overhauled (rings etc.)? Thanks
Walt Davies
06-25-2006 20:27:06
 Re: Case IH 3230 Excessive Smoke Problem. in reply to 4010 Pride, 06-25-2006 09:42:04
That's hard to diagnose from here because it could a lot of differant things that cause this. A bad air filter, plugs air intake, injector pump worn or badly out of adjustment, worn rings low compression. I would say if you don't have the knowlegde now is the time to take it to a good shop for a look at.
Walt
