Diesel won't start
Keith
11-13-1999 16:26:25
Guys I need some help!
I have a 450 track loader that I put on quite an angle cleaning up my house lot... Well after throwing a track by running over a rather tall stump the diesel decided to stall out and not re-start. My thought is that at the extreme angle that I needed to put the machine on in order to change the track and the fact that I am on the side of a mountain caused the motor to gulp air. After adding fuel again, how do I bleed the fuel system? Also,how do I use the bleed screw on the top of the filter? The injection pump does not have a manual pump. Do I open the injector lines and turn over the engine? Are there any special tricks that I need to know? Does anyone know of any other reason it will not start and what I should check? It was running great this morning before I beat it to a pulp?
Please help!
Keith
P.S it really sucks to have to haul a hundred pound battery 500' up and down to my truck for recharging for tomorrow's adventure!!
Bob Read
11-15-1999 16:53:53
 Re: Diesel won't start in reply to Keith, 11-13-1999 16:26:25
By now, you may already have your engine running. However, let me tell you of the method I have used many times. I learned this trick from an old mechanic-dealer for I-H. You need to get the fuel from the tank (assuming that you now have enough fuel in the tank and will no longer be drawing just air into the lines.) The easiest way to do this, is to go buy another fuel tank cap. Drill a hole into the center of the cap, preferably in the center of the brad or rivet in the center on the cap. Insert a rubber valve stem. Get the longest valve stem you can find for a car or pickup tubeless-tire wheel. Make the hole just large enough to hold the rubber stem tight and then replace the original tank cap.
Next, open the vent plug on the fuel filters. Apply pressure to the valve core stem, and watch for fuel to emerge from each filter. BE CAREFUL AND DO NOT ADD TOO MUCH PRESSURE!!! Less than 5 pounds will usually do the job. Have someone watch the bleed holes and cap them as they begin to bleed pure fuel. If needed, ADD MORE AIR PRESSURE, SLOWLY. ALLOW A FEW MINUTES FOR THE FUEL TO MOVE THROUGH THE LINES AND EACH OF THE FILTERS. You do not need to purge the injectors or injector lines. The injector pump will do that very easily, once you have gotten fuel to the pump. When all lines and filters have been purged and secured, start the engine. I have done this many times because the manual pump on my fuel system did not work. I have also done this on my Chevy Blazer. Once you have finished bleeding the system, replace the altered fuel cap with the original one. Also, be careful then you release the pressure from the tank. The fuel will "boil" over like a Coca-Cola does when it is first opened. Good Luck. And, keep the cap for the next time you change filters, etc.
Keith Running Thanks!
11-15-1999 05:35:55
Thanks everyone!
Good advise helped me get my brain in acion! Because of the extreme angle I wasn't able to get any fuel to gravity flow to the front fuel filters. What I did was mount a jerry can on the hood and siphon feed directly into the injector pump feed line. After she fired up I moved to a level surface and fuel began spurting from the tank. With fuel flowing easily priming became obvious! I think my filter was air leaking when it was out of the gravity stream.
It is great to have a place to ask advise! Thanks everyone for the help!!
Keith
Keith
11-14-1999 04:53:35
Thanks guys!
I'll let you know how I do!
Keith
Len
11-13-1999 21:49:42
The bleed on the top of the filter is loosened until you have fuel and no bubbles. You shouldn't have to bleed injectors. After being certain you're getting fuel to the pump, crank it(with bleed closed). It it's getting fuel you'll see good color in the exhaust (or if it starts without ether, it'll start.) Don't use ether except as you would for any other start at this temperature. If it's not getting fuel don't try to run it on ether.
Mike H
11-14-1999 19:08:41
 Re: Re: Diesel won't start in reply to Len, 11-13-1999 21:49:42
If you don't bleed the injectors it probably won't start.Because if there is air in the lines when you crank it the air compresses like rubber sesawing back an forth and won't let fuel in
Len
11-14-1999 21:19:04
 Re: Re: Re: Diesel won't start in reply to Mike H, 11-14-1999 19:08:41
Air to the pump doesn't automatically mean air in the injector lines. But trying to bleed the injectors before there is fuel to them will guarantee that they need to be bled.
Wayne
11-13-1999 19:20:49
If it were possible, I would drag the machine around the other way to get the fuel to the other side of the tank. If not, fill the tank with fuel. Open the bleeders on the fuel system. There are probably more than one. Ether may not help, use it sparingly by the way. Last ditch effort, get the operators manual and see where else to bleed it. Try everything in that order first. Don't crank it more than 30 - 45 seconds at a time. A starter would be just that much more to drag up the hill. Good luck. Any other time besides Sunday AM also.
