Case 430 / 600B Fluid Capacities
Lee Brown
06-24-2006 10:48:50
Hello! I'm putting my 600B Case-O-Matic together and want to know if there is one reservoir for hydraulic & COM transmission fluid or more than one. If it's combined, how much fluid does it take? I'm assuming Case IH Hy-Tran is the proper stuff, but correct me if I'm wrong.
Also, I've changed the hydraulic fluid in my 430 Diesel (Tripl-Range w/ Draft-o-matic), but I think there is a separate reservoir for the transmission fluid. Does Hy-Tran go in there as well? If so, how much does that compartment take?
I went to a dealership, but I'm not sure that the guy there was looking on the correct line in his book for my tractors, so I thought I'd check it out with you experts!
Thanks for the help!
Lee
rongrong
06-24-2006 19:54:10
 Re: Case 430 / 600B Fluid Capacities in reply to Lee Brown, 06-24-2006 10:48:50
for your 600b the caseomatic and hydraulics use the same compartment for oil in my owners manual it says to use atf oil,but a friend uses case tch oil which means trans,converter,hydraulics..you would have to check if hytran is the same as it is the old ihc brand.. also the oil capacity is 4 us gallons
